1/2
1
2
ETFE
gulei
请大家关心一下ETFE材料的充气膜。国外用过,国内将有很大的应用。
欢迎上载资料。
ETFE
2003-10-1 03:27
ETFE的中文名为乙烯-四氟乙烯共聚物。ETFE膜材的厚度通常小于0.20mm,是一种透明膜材。 2008年北京奥运会国家体育馆及国家游泳中心等场馆中将采用这种膜材料。
ETFE膜材常做成气垫应用于膜结构中。最早的ETFE工程已有20余年的历史,而最著名的要数英国的伊甸园了。
ETFE
2003-10-4 00:12
08年北京奥运会的两个ETFE场馆。
ETFE
2003-10-4 00:16
“水立方”夜景
ETFE
2003-10-4 00:21
内景
ETFE
2003-10-4 00:23
计划用于建造“水立方”的元件
ETFE
2003-10-4 00:36
这样的ETFE气垫将安装在上述元件组成的构架上
davidchen
2003-10-7 03:13
ETFE is not very popular in the world because of the following reasons:
1. Limited strength: Can only span about 3 meters.
2. Excessive flexibility: The only scheme to use this material is “cushion”.
3. High translucency: This is its selling point but also can be translated as its weakness. Television may prefer controllable artificial lighting instead sunlight which changes direction all the time.
4. Mechanical equipments: Cushion requires the supply of pressurized air. For the Main Stadium, there could be as many as 13,200 cushions that need to be monitored for leakage.
5. Electricity: To ensure supply of air, back up system or systems will be needed.
6. Vandalism: Sharp objects can damage the material and cause air to leak. Flying debris also can cause substantial damages to vertical surfaces.
7. Initial investment: The initial cost is very high, as high as glass panels.
8. Maintenance cost: Daily maintenance is required. A maintenance crew should be kept.
ETFE
2003-10-7 22:34
由于ETFE具有极好的透光性能,因而特别适合用来建造需人工模拟自然环境的建筑场所如动植物园、人工雨林等。从建于80年代初的jungle house到2001年的伊甸园再到几个月前刚建成的Masoala 雨林,都堪称这方面的代表之作。
就造价而言,虽然ETFE气垫的价格不比玻璃低,但由于其质量极轻,因而在整体结构及基础方面的节省还是相当可观的。
ETFE
2003-10-13 23:27
IFAI 2003 International Achievement Awards
Outstanding Achievement Award
Masoala Rain Forest, Size: 90 m X 120 m
3D Image
http://www.masoala.ch/masoala_regenwald/en/panorama3.html
crow
2003-10-15 09:05
北京奥运工程决定启用ETFE,是不是会推动ETFE在国内的发展呢?而当今可以做ETFE的有那些公司?
yangjunok
2003-12-2 16:09
提供masoala工程的图片一张(花了我好长时间在才找来的)!
不知道是哪家膜结构公司设计施工的?有谁可以提供?
pan
2003-12-2 17:46
Masola Rain Forest, Zoo Zurich-------By COVERTEX
pan
2003-12-3 09:47
swimming pool "Moby Dick"
pan
2003-12-3 09:50
德国慕尼黑的Allianz Arena
pan
2003-12-3 16:40
ETFE膜材料介绍
ETFE膜是透明建筑结构中品质优越的替代材料,多年来在许多工程中以其众多优点被证明为可信赖且经济实用的屋顶材料。该膜是由人工高强度氟聚合物(ETFE)制成,其特有抗粘着表面使其具有高抗污,易清洗的特点。通常雨水即可清除主要污垢。
ETFE膜使用寿命至少为25-35年,是用于永久性多层可移动屋顶结构的理想材料。该膜材料多用于跨距为4米的两层或三层充气支撑结构,也可根据特殊工程的几何和气候条件,增大膜跨距。膜长度以易安装为标准,一般为15-30米。小跨度的单层结构也可用较小规格。
ETFE膜达到B1、DIN4102防火等级标准,燃烧时也不会滴落。且该膜质量很轻,每平方米只有0.15-0.35公斤。这种特点使其即使在由于烟、火引起的膜融化情况下也具有相当的优势。
根据位置和表面印刷的情况,ETFE膜的透光率可高达95%。该材料不阻挡紫外线等光的透射,以保证建筑内部自然光线。通过表面印刷,该材料的半透明度可进一步降低到50%。根据几何条件及膜的层数,其K值可高达2.0W/m[$sup2]K。耗能指数以一个三层印刷的膜为例可达到0.77。
由于其优秀品质,ETFE膜几乎不需日常保养。可对其由于机械损坏的屋顶进行简单检查(一年一次为宜),并根据需要就地维修。同时也可检查通风系统,更换过滤装置。
ETFE膜完全为可再循环利用材料,可再次利用生产新的膜材料,或者分离杂质后生产其它ETFE产品。
yangjunok
2004-1-18 14:23
不知道楼上的老兄能否再具体地结合工程项目(例如水立方或者Masola)详细 讲解一下呢?
谢谢先!
wendi
2004-1-28 21:47
不知对下冰雹的抵抗能力如何?
TOOEASY
2004-2-4 12:10
ETFE与PVC,PTFE完全不同,就像大家了解的汽车一样,欧1到欧2比较容易,而欧2到欧3就完全不同了。
初步分析,鸟巢改用PTFE有一下几点原因:
1,其膜面积至少比水立方还要大一半,这么大的面积应用,在世界上是没有的,膜结构与钢结构的衔接有很大难度;
2,其大面积开启式屋顶更增加了设计与施工难度,恐怕也是目前世界上独一无二的;
3,规避风险,两个奥运主场馆,既然水立方用ETFE,鸟巢改用PTFE也在情理之中;
4,ETFE确实有优点,但也确实有缺点,而鸟巢更需要PTFE的优点,换句话讲,PTFE更适合鸟巢,包括从结构等各个角度;
5,……
本人同意Mr.davidchen的观点,现阶段ETFE的应用还是要分场合,视具体情况而定吧。
向Mr.davidchen问好,祝元宵节愉快!
szowen
2004-2-4 15:43
水立方继续用ETFE我觉得漂亮、美观大方
yangjunok
2004-2-17 16:50
水立方继续用ETFE我也觉得挺漂亮的!
不过如果鸟巢改用PTFE后还会有预期的效果吗?至少没有原来鸟巢效果图漂亮了吧,也许会是白白的一片,或许年久后成了灰灰的一片呀,不可想象……不可想象!我觉得还是ETFE感觉好!
he1204
#22
2004-2-19 10:20
1。见到的这几个ETFE的工程的膜的单体面积都不大,建筑效果上有些类似玻璃幕,有其他形式的工程吗?
2。ETFE的裁减加工是否和其他膜材(PTFE,PVC)的方法一样?
red
#23
2004-2-19 14:53
又一处新的ETFE项目.1
red
#24
2004-2-19 14:54
2
red
#25
2004-2-19 14:55
3
mibao
#26
2004-2-19 15:05
也来介绍两组ETFE膜工程
1
mibao
#27
2004-2-19 15:05
2
ynliu
#28
2004-2-27 20:30
加油站可
ynliu
#29
2004-2-27 20:45
ynliu
#30
2004-2-27 20:45
45
1/2
1
2
